AERO CDI makes my Spree super fast
Johnniespeed
My three Spree's pull pretty good to 27, then slowly creep to thirty. Except my fourth Spree , it pulls strong to 33 then creeps to over 35. The difference ? The fourth Spree has a CDI box from a 1984 Aero 50 on it. When I put a stock Spree CDI box on it, it runs the same as all the other Spree's, I plug the Aero box back in and the power/speed return.
So apparently the timing curve/timing advance must be better on the Aero box.
Has anyone else discovered this ? Where can I buy more1984 Aero 50 CDI boxes ? Does the aftermarket CDI pull as strong as the Aero unit ?
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
Re: AERO CDI makes my Spree super fast
from what i have read on this forum all cdi's are about the same, and they almost never go bad, and there is no point in buying the derestricted cdi's
that being said, that is all 2nd hand knowledge and you very well may have proved them wrong. any pictures to verifi this discovery?
now im wondering where i can find a box of assorted cdi's lol
- patthesoundguy
Sprees have slight differences between the 84/85 and the 86/87 model years. The 84s are more like 28mph top speed and 87 is supposed to be more like 30-32 I think it is. That may have more to do with it than the cdi change I'm betting. But who knows maybe there is something to it im thinking no. What years are the the scoots in question. Things like air filter condition and air box lid gaskets could be factors as well. Make sure you verify the speeds with a gps the speedos could be off too, my spree is only kinda accurate, depending on when you read it. My aero 80 is off by a whole needle width. If I'm going 70km/hour it reads 73 at least there is 1.6 km in a mile that's almost 2mph faster on the speedo than the true speed on the GPS.
Here is the reed blocks from an 87 and an 84 the smaller one is the 84.
Johnniespeed
Lets not get confused here, this is not about other bikes, ports, reeds, belts, variators, Pipes, tire size, wind direction or rider weight.
The same Spree with a Spree CDI is normal speed, the exact same Spree with an 84 Aero 50 CDI is significantly faster, no mods, no other changes. Normal speed with Spree CDI , much faster with 84 Aero 50 CDI. No matter how many times you switch it back and forth the Aero CDI is much faster. The bike runs perfect with both. The speeds were measured with a Garmin GPS.
I simply was asking if anyone else had discovered this, I already know it's true, I have already proved it, that part is not up for debate.
I have read on this forum, that the " Performance " CDI sold on ebay is not different and fails soon, I am now doubting that claim, unless someone has proof.
Has anyone actually compared the Stock Spree CDI against the "Performance" CDI ? Is the "Performance CDI" an Aero CDI ?
kind of sassy jonnie and i like it. im really wondering if my 84 cdi is would be giving me performance gains or losses in my 87 aero engine. ( i did a swap) i should try the cdi from a 85 i have lying around. ( when i get her running again
but whatever, haters going to hate. if someone buys a racing cdi i cant wait.
Johnniespeed
This isn't about my Spree being special or about an 87 spree going 32.
Obviously there is a different timing advance map inside the 84 Aero CDI.
Does anyone here know how to log the data of the ignition advance curve ?
- swimmingfree
Johnniespeed
ill wood like you to try the cdi on one of your other spree to see if you gain more speed out of then ... im running a se50 with a spree cdi and not getting the rpm (= speed) out of it and it wood be nice if you gave some photo and id number of the 84 Aero cdi box... so other may try it ...
thank you ...
thank you ...
ill bet you a lot of us have been using the wrong cdi as a result of bike swaps and this guy just discovered it.
- swimmingfree
im not saying he is right or wrong .. i have fue cdi box laying around here and wood like to see if some one can get the same out of a 84 Aero CDI as he did ...
i 2nd that, i want pictures!!!swimmingfree wrote:im not saying he is right or wrong .. i have fue cdi box laying around here and wood like to see if some one can get the same out of a 84 Aero CDI as he did ...
have you tried that cdi on your other sprees?
i really want some of the more advance two strokes to chime in here...
how does a cdi know the positioning of the piston? does a different cdi just act like a good port job?
Spree findings are interesting, and worth looking into for more info on whats going on here.
Let's record the variables for others. What Spree model year is being used? What p/n CDI are you swapping in/out as the Spree reference and what p/n is on your Aero 50 CDI? See below - there were 2 different CDI's in Sprees.
Honda has used several CDI's during the 80's in various models. Aero 83/84 CDI is relatively uncommon, it was only used in that model. Most of us do not have an 83-84 CDI.
-- Spree CDI History --
Spree had one version for 1984-85 (30410-GK8-784) and another for 86-87 (30410-GK8-784). For either Spree, the same CDI was used for restricted and non-restricted models.
30410-GK8-784 (86-87 Spree CDI) also used in all other US two stroke Hondas 1987 to 2001.
1987 Aero 50 NB50
88-2001 Elite SA50 (AF05 and AF16) Restricted and Non-Restricted
1988-89 Elite SB50
IMHO - I'd hold back buying CDIs to try out on AF16's and variated AF06's on current info. CDI is not holding RPM's back on modded engines.
1987 Aero 50 NB50
1988-89 Elite SB50
Yes - I can capture via oscilloscope.Does anyone here know how to log the data of the ignition advance curve ?
i do have a parts 85 aero i guess i could swap the cdi into my 84 little blue. but she isnt even running yet so i feel weird having her donate parts. but its for the sake of the forum!
this issue reminds me of a post i started last year posting.php?mode=reply&f=3&t=24949
- martynkim
I have a CDI from an 83 Aero. But, no Spree to test it on.
- patthesoundguy
Hey dude, with that kind of proof there has to be something to the cdi for sure. I'm willing to order one of those performance cdis and try it on my spree to see if it has any gains, they are relatively inexpensive. I'm super curious now to see what happens. If one can gain a couple mph with just a cdi box change, to me that's a huge breakthrough.Johnniespeed wrote:Lets not get confused here, this is not about other bikes, ports, reeds, belts, variators, Pipes, tire size, wind direction or rider weight.
