86" Spree Electric Start INOP
flyingdiver31
Post by flyingdiver31 »
I'm still working on getting the motor to run good on my 86' Spree but also have a new problem, the electric start button won't work. I have looked at all the connections to ensure they are tight and not corroded. Everything looks good but it seems electrically dead. I remember reading somewhere in this forum that there was a way to by-pass something to try to get the starter to accuate, can anyone tell me how to do that?
Were there know electric start issues on the 86' Spree that I should start with first?
Thanks
Doug
martynkim
Re: 86" Spree Electric Start INOP
Post by martynkim »
flyingdiver31 wrote:I'm still working on getting the motor to run good on my 86' Spree but also have a new problem, the electric start button won't work. I have looked at all the connections to ensure they are tight and not corroded. Everything looks good but it seems electrically dead. I remember reading somewhere in this forum that there was a way to by-pass something to try to get the starter to accuate, can anyone tell me how to do that?
Thanks
Doug
Are you appling the brake when you attempt to start?
flyingdiver31
Yes and the brake light comes on when I do.
With the brake light working, competing troubleshooting is just a few tests more.
1) Answer to your question ' I remember reading somewhere in this forum that there was a way to by-pass something to try to get the starter to accurate, can anyone tell me how to do that?'
Bridge the Red wire to the Red/White wire at the Starter Relay connector.
2) If the starter runs, it's either the relay or the coil energizing circuit (starter button, gnd, wiring)
