85' Aero Running Away issue- after 2 chem dipped carbs
Posted: Tue Jul 02, 2013 1:09 pm
I am thoroughly frustrated.
My 1985 Aero starts up, but when I give it throttle it slowly takes off then stays up in the high revs and won't come down unless I turn it off.
Ruled out the throttle cable already by borrowing one from a friends that worked and it still had the same problem.
After I thought my scoot was running lean, it turned out the gas air mixture was fine.
However, my carbs holes for mounting to the intake were so stripped I thought it was causing an air leak.
After ordering a new carb off of ebay, I found that it too had stripped out.
I chem dipped both of them, made sure they were extremely clean, then found some jam nuts to make sure they were on tight enough to the intake, BUT STILL, the same problem persists!
I tried both carbs, but used the guts of the one that was in better condition.
Do I need a carb rebuild kit?
WHAT IS THIS SORCERY?
I swear to god, whoever helps me figure out what this is can have my extra spree starter and oil pump.
BTW- this is a picture of the bike, actually a kinda cool art project my friend and I worked on.
It's entitled "Lines and Shapes"
