Ruima crank shaft good???
- paulpauly7
Ive just bought a new old stock Ruima stock stroke large shaft crank for my niftydio anyone used one of these ?Are the any good ?
Its got to be better than the stock crank i have now that has a bugged big end conrod bearing it made some serious noise when it went out no damage any where else thank god id be gutted if i had killed my new corsa
- paulpauly7
Re: Ruima crank shaft good???
anyone?
I've had a Ruima ministroke for about 1000 miles. Worked fine during that period.
- Trafficjamz
I've heard that when it comes to reliability, stock honda is the best.
But if your stock crank has buggered up ends, I say go for the NOS Rumia.
- paulpauly7
thanks for the input.Theres a crank shop here who fit stuffer inserts i will look in to how much this costs .It would be great to get some more crank case pressure
what do you mean by NOS ruima
- paulpauly7
well i got i priced up stuffer inserts can be fitted to any crank including oem but the down side is $300nzd so that aint gonna happen id rather buy the malossi crank.But any way they reakon they can spin it up and balance it up better that it is (after they check it ) for $20 so ill that instead
That is pretty impressive they can do the insert job and balance it so well. They must weld the inserts on with TIG.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- paulpauly7
they talked about drilling holes either side of the pin the the inserts come thru .The insert has metal tabs on the ends that then get welded lots of work
new old stock ruimapaulpauly7 wrote:what do you mean by NOS ruima
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- paulpauly7
i thought so but wasnt sure
