oil plug leaking
t8kinover.
oil plug leaking
Post by t8kinover. »
I noticed today that my oil plug is leaking. has anyone else had this issue? the oil plug is the one vt cycles sells. any tips on sealing it?
Sent from my SCH-I500 using Tapatalk 2
t8kinover.
Re: oil plug leaking
ok yah I did notice the threaded hole on the back of it. I can't quite picture how that would work. I'll have to take it apart again I did get it real tight when I installed it. I was woundering if anyone else had this problem? mabey I could put an extra o ring on or something teflon tape idk.
Mine have leaked too. Last time I had the engine off I slathered it with Hondabond before tapping it in. Seems dry since.
t8kinover.
ahh yes. I think that is the solution.
Now the threaded hole serves a purpose ;-)
t8kinover.
geeze I just was looking for some ideas thanks for the help though.
t8kinover.
yah kno after looking at it i c what ur talking about alot of your words were un nescessary rember your s*** smells just like everyone else
I did not intend for the reader to get the impression that I relied on Hondabond alone to secure the pump plug.
The Hondabond filled the gap between the case hole and the plug, but the plug itself is secured by an extra-large fender washer, properly shimmed to apply pressure to the "mushroom" end of the plug. The tapped hole may prove useful if it ever needs to come out; Screw in a 6mm bolt and then use the bolt to pull out the plug. Use a gentle touch with a slide hammer if necessary.
milkhuman wrote:theres no where to hondabond, and anything else, would blow out. or suck in.
you can use honda bond on the plug before you install it to get a better seal.
paulpauly7
Post by paulpauly7 »
honda bond is a rtv like sealer you smear some around the plug and install 24hrs later the honda bond is set and your plug is sealed
paulpauly7
yes you do need the washer spaced out to hold it in place the honda bond just helps the big job the little O ring has to do .
paulpauly7
im talking about a smear not half a tube gees really dude get ahold of yourself you babbling makes no sense
Cherreh SR
Post by Cherreh SR »
paulpauly7 wrote:yes you do need the washer spaced out to hold it in place the honda bond just helps the big job the little O ring has to do .
If you don't mind can't you explain this spaced out washer to hold it in place? I have no clue what you mean and I'm installing mine in a few days. A picture with an explination would be awesome if its not to much of a bother.
evilone
Post by evilone »
milkhuman wrote:nooo.
DONT EVER PUT RTV SEALANT IN YOUR PLUG PUMP> EVER THIS WILL BREAK YOUR MOTOR FOR SURE> WHy not just open it up and dump the tube down in it. i think ive explained itll suck in or blow out.
Hey trains420, how does hondabond work for the case halves then?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Once again, my use of Hondabond was only to seal. The plug is secured with a fastener over a large washer, shimmed to apply pressure to the plug. Don't overdo the Hondabond and it'll be fine.
Red Eft Performance
Post by Red Eft Performance »
sometimes the plug wont sit flush with block so you need to add a washer or two on top of the plug.
This is trafficjamz picture. looks like this plug is flush with the block.
Red Eft Performance
View products click => Here
