stock block dio project is on
A bone stock sa-50 block that i will transform into a 60mph sleeper, this will be a first on this forum!
Re: stock block dio project is on
pictures forth coming???
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
- paulpauly7
the first hahahaha i dont think so buddy
dabinonahonda
very far from a first if u would bave said 100mph maybe lol and we all know thats not going to happen
1988 hd sportster 883 evo
1983 hd sportster 1000 roadster
2001 Honda elite s
2001 Honda elite s
Graphite's feat is unprecedented and worthy of respect. But you are sounding like MadDog when you say it like that.
- Trafficjamz
a 60 mph sleeper?
That may be a challenge.
Once the scooters go 60 mph they are usually pretty obviously modded.
Maybe SLEEPER is the key.
He means sleeper as in he was a sleeper when he dreamed of it.
- steffen707
I think the decibel levels of your intake and exhaust may be a dead give away.maddog wrote:A bone stock sa-50 block that i will transform into a 60mph sleeper, this will be a first on this forum!
If you make it go 60mph with stock intake db levels and stock muffler, then I want one!
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
XX Yamaha YSR50
- steffen707
but not a sleeper. I have a bbk, pipe, carb and 9:1 gears and hit 59.2 during lunch. It also looks like I slapped a bunch of after mkt stuff on it, hardly a sleeper.graphite9 wrote:Maybe he is going to put a DC motor and car battery on it . You could do it with a really large rear tire, a tailwind, a downhill slope and 7:1 gears. Maybe some bottle rockets on the bike.
Stock block means just the bottom end. If thats what your referring to, several people have done it. Bbk pipe carb gears and your there.
87 Honda Spree,
XX Yamaha YSR50
XX Yamaha YSR50
Im talking " Bone stock" = 60 mph, my old stock block did 53mph all day long for 29,000 mi. with dio pulleys and some porting its a done deal, bore kits are not needed.
- steffen707
It might hit 60mph if you drop it off a really tall building. Or pull it behind a car with a tow strap.
87 Honda Spree,
XX Yamaha YSR50
XX Yamaha YSR50
maddog : this is a comment DIRECTLY to you.
After becoming disgusted with your behavior on this site,
particularly when Bear would get involved and call you every insulting name in the book,
I decided to block your posts.
It was a very good time here without seeing any of your laughable fairy-tale stories.
Once the Bear stopped posting here, I decided to un-block your posts and see if you ever had anything worthy of reading.
It seemed that you had stopped all the insanity without the Bear to encourage you.
Now, I see that you still possess the urge to make claims of fame and greatness with the same lack of credibility.
Why don't you man-up, put up pix, and give details of your scooters, and just be a STAND-UP guy.
Continuing with RUNNING YOUR MOUTH is nothing more than just that, and you PROVE IT every time you post.
Some members have stated in the past that you are not the idiot you try so hard to display.
I'd like to see some evidence of that person who is not just another A-S-S-hole.
Common dog show some videos or something!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- steffen707
the bear no longer posts on the forum?motormike wrote:maddog : this is a comment DIRECTLY to you.
87 Honda Spree,
XX Yamaha YSR50
XX Yamaha YSR50
Once this year...steffen707
