frame/drag brace
frame/drag brace
I was wondering about if it would be worth cutting the plastics to install one. I would like some opinions from people who have used/made one for their scooters. thanks
- paulpauly7
Re: frame/drag brace
i fitted a frame brace to my spree to stop frame flex .I think it does its job great much more stable at high speeds
- patthesoundguy
Sprees have a ton of frame flex, I don't have a frame brace but I think they are a super great idea. To figure out if its a good idea to cut your plastics or not you need to think about how much you would like having no frame flex as opposed to having some holes in the plastics. It could be tough to decide
- paulpauly7
just fit one with out the plastics take it for a ride and see what you think.If you dont like it remove it that way you save the plastics
You could weld a reinforcement spline on the bottom of the frame and that could add some serious support. I imagine all the flex happens on the front of the frame from about where your toes go. If you could fab a little gusset there it might solve the flex w/o any plastic mods.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- patthesoundguy
Now that is using ones brain B-) right onpaulpauly7 wrote:just fit one with out the plastics take it for a ride and see what you think.If you dont like it remove it that way you save the plastics
