honda aero 50 and honda metro rear wheel
jaysonneff
Post by jaysonneff »
are the rear wheel on the honda aero 50 and the honda metropolitan the same? i need to know Please :coolcruise:
87 Honda Aero 50 nb50
Kevinstonge
Re: honda aero 50 and honda metro rear wheel
Post by Kevinstonge »
Not sure if you found your answer in your other thread, but just in case..
They are different. The aero should have a 10x1.5 non-tubeless wheel. The met has a 10x2.15 tubeless wheel.
Good news is that the met wheel fits on the aero with a 90/90 tire. Wheelman mentioned possible rubbing on the center stand, but I didn't run into that issue on my 85 nb50.
jaysonneff
thank you
jaysonneff
are the rims the same?
deuce217
Post by deuce217 »
I am tracking that the metro is designed for tubeless. Which is why the metro wheel is popular to switch to for cooler tire options.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Kevinstonge
Correct. Cooler and larger diameter;)
