crank shaft nut keeps falling off
Posted: Mon Aug 05, 2013 2:58 pm
by crimespree
Its happened twice now and I think if it happens again there won't be any splines left to put it on. What do you guys use to lock it down. Red lock tite, lockwasher? Jb weld?
I can defiantly crank it down tight with some of my climbing rope in the cyl keeping it from doing a full stroke
Re: crank shaft nut keeps falling off
Posted: Mon Aug 05, 2013 3:27 pm
by paulpauly7
dont do that .Hold the drive face with a strap wrech or oilfilter remover and tourqe it to factory specs maybe with a little red lock tight .youll put your crank out of true by trying to hold the piston
Posted: Mon Aug 05, 2013 10:05 pm
by Red Eft Performance
I personally use the Blue lock tight just cause I take it on and off so frequently.
Posted: Wed Aug 07, 2013 8:06 pm
Ditto on never losing one yet, and I DON't use an impact. I'd suspect an issue with the splines; If the outer pulley sheave isn't seated correctly, the nut feels tight but it gets loose once the sheave settles back into its correct position. Hopefully you haven't mangled the sheave, or worse - the crankshaft. Confirm by carefully removing the belt cover once the engine is idling. Look for a wobbly pulley.
