Anyone running a Spree with a stock carb? What size main jet are u using? Air filter? Has anyone drilled the stock carb pilot circuit with good results? What size bore did u use?
Thnx for your help.
Spree 48mm BBK JET
Re: Spree 48mm BBK JET
I use the stock carb and jet that Taz sent with the kit. I think the jet is a 87. I drilled three 3/8" holes in the air box lid but I think the instructions call for 4, 1/2" holes. I idle great with my carb set a little rich at 1 1/2 turns out
Thnx. I need to find a lid for my airbox.
