question about interchanging parts
ryan.ott
Post by ryan.ott »
I was wondering if the elite body panels are all the same will they interchange between years. And are the older pre 93 wiring and lights able to work with newer years lights,cdi, etc.
Also was wondering will a 2000 sa50 engine bolt into a spree the same as it will in a 93 or older elite
hrnytrtlsgsxr
Re: question about interchanging parts
Post by hrnytrtlsgsxr »
ryan.ott wrote:I was wondering if the elite body panels are all the same will they interchange between years. And are the older pre 93 wiring and lights able to work with newer years lights,cdi, etc.
from 94-2001 plastice of the elite s are the same.The wiring components like the cdi, voltage regutator are the same.the wiring harnest will be differnet in lenghts depending on what model it came from but they are basically the same with the components in different areas of what moped it came from.
ryan.ott
Post by ryan.ott »
What about fitting a 2000 engine in a spree
hrnytrtlsgsxr
ryan.ott wrote:What about fitting a 2000 engine in a spree
you will need to modify a motor mount like an 87 elite motor mount or if you can weld. cut and welf the elite 2000 motor mount to the spree motor mount. Than the shock mount will have to be moved back a little like under the battery holder or oil tank.
