stroker
mmeadows
stroker
Post by mmeadows »
why are stroker cranks not recommended for daily use?
is it the case is likely to leak air? none are available with an oil pump gear?
or.....
kingearwig
Re: stroker
Post by kingearwig »
IRC my ruima 43.4mm mini stroker (no case mod needed) has the worm gear for an oil pump. I also had a stock sized crank that did not.
Re: stroker
mmeadows wrote:why are stroker cranks not recommended for daily use?
or.....
What?!! who said that?
There is a 50mm crank from PG that has the oil pump gear.
If your stoker is built well, it should not leak air.
A stroker crank will hammer on the bearings and chew up belts a lot quicker than a stock crank will.
So i guess reliability of the scooter would be one reason not to have a stoker for a DD.
mmeadows
Re: stroker
Post by mmeadows »
[/quote]
So i guess reliability of the scooter would be one reason not to have a stoker for a DD.[/quote]
thats what i was wondering. maybe one could counter these issues with ceramic bearings and trying to carry an extra belt?
are ceramic bearings "stronger" or just more heat resistant and less likely to fail.
fujio001
Re: stroker
Post by fujio001 »
Ceramic bearings are harder and not stronger. They are used in road cycling and tests show they really are not faster under load. When improperly matched to soft bearing races, they can actually be slower because they deform the bearing races. What really matters is the roundness of the bearing. Bearings in other uses often use an ABEC scale to measure how round they are. Higher the number, the less resistance they offer and the faster they can be.
