Page 1 of 2
oil transmission
Posted: Tue Sep 10, 2013 2:58 pm
by schols44
Does my 1998 elite SR need oil in the transmission? I mean do i need to add oil somewhere else that in the oil tank under my seat?
Thanks
Re: oil transmission
Posted: Tue Sep 10, 2013 3:30 pm
by paulpauly7
download the manual and have a read
Posted: Wed Sep 11, 2013 7:18 am
by swimmingfree
schols44 wrote:Does my 1998 elite SR need oil in the transmission? I mean do i need to add oil somewhere else that in the oil tank under my seat?
Thanks
the transmission ( finale drive ) need oil as well as the tank under the seat.... look it up ....
Posted: Wed Sep 11, 2013 11:58 am
by schols44
Just checked the manual but it doesn't show how to fill it in. Can i use the same oil as the one i put in the oul tank? It's been 2 years that i have this scooter and i have never add oil at this place, but only in the oil tank...
Posted: Wed Sep 11, 2013 3:30 pm
by bfowler
If you look at the manual it tells you what kind of oil to put in the gear box. Its not the same as the oil you put in the oil tank.
Posted: Wed Sep 11, 2013 4:37 pm
by LMH
Heya, I use 75-90 gear lube by royal purple. It doesn't take much at all. Drain out all that old junk and let it drain for a while before you fill it back up. Royal purple gear lube can be found at oreilys. I don't know where you are in st Charles but there's a lot of them out there. If you need help I can help out sometime this week while I'm in town.
Posted: Wed Sep 11, 2013 6:34 pm
by bfowler
Pretty sure it's 10w-40 oil needed.
by Trafficjamz
Just use regular motor oil in the trans case.
10w30 is what I use.
Posted: Wed Sep 11, 2013 6:39 pm
by LMH
Oh crazy Ive always ran 75-90 with no problems, I just assumed it was like the other bikes. Do you think it can cause any issues? I havent seen anything ever go wrong with mine but maybe its just good luck.
Posted: Wed Sep 11, 2013 6:45 pm
by LMH
Im going to swap out with some GN4 10w 30 later tonight and see if theres any difference. Might have to do it a couple times. I know my yamaha used 85-140. 10w 30 is a lot cheaper.
Posted: Wed Sep 11, 2013 6:50 pm
by bfowler
Manual says 10w40 but you can also listen to traffic. He definitely knows his stuff.
Posted: Wed Sep 11, 2013 6:51 pm
by Trafficjamz
LoveMyHonda wrote: Do you think it can cause any issues? I havent seen anything ever go wrong with mine but maybe its just good luck.
Im pretty sure you will be fine with gear oil.
It just is overkill. some people would argue that the thicker oil would cause more resistance.....but Im not really sure ive ever noticed a difference.
Posted: Wed Sep 11, 2013 7:06 pm
by paulpauly7
i run 10/30 with a splash of lucus oil treatment it clings to the gears
Posted: Wed Sep 11, 2013 7:16 pm
by LMH
Well you saw how fast my 49cc is, my 72s are killer faster ha. I thought maybe it may blow out a seal or something. the 75-90 works great so far but Im definitely going to change out one of the zx50s and see if theres any difference. Thanks!
Its funny because I was going to swap gears in my 49cc tonight and Im glad this came up. Learn something new everyday!
Posted: Wed Sep 11, 2013 9:06 pm
by cruzingratiot
viscosity oil chart
75-90 gear is equlivent to 10-40 engine oil see chart below
http://www.bobistheoilguy.com/viscosity-charts/
from
a lot of good reading about oils
Paul Jug
