Tuned performance pipe for Spree...
How much would you be willing to pay for a tuned pipe for the Honda Spree? This is for a pipe that's been proven to work on at least one Spree and gets some sort of speed improvement. Vote up above, as far as what you'd want to pay and what you'd want to get. This is something I've been puttering with for awhile. It won't take much more work to knock out several of these if I have to build one.
I thought Dallasmysterycrew was going to take this on, but I haven't seen anything from him for awhile now, so who knows where he is on this project....
"Under $100" was pretty much the consensus.
I've thought about making some up to sell, mostly to pay off the MIG welder I'd need to buy to weld them up. Not sure there's enough interest, though. I'd modify a Chinese pipe, though, rather than make one from scratch. Like I did with mine.
Admin, Hondaspree.net
- hrnytrtlsgsxr
Depends on how slow you were to begin with. One guy jumped from 25 MPH to 34 MPH (indicated,) which is where the title came from (this is a really old post.) I got something like 5 MPH with the one I built, and a lot better topend power. You lose something on the bottom end, though, so you need to bring up the clutch RPMs to compensate.
And yeah, that was the only change I'd made. I'd like to take the same scoot, report the exhaust slightly (enlarge and advance port timing), get the pod filter working with the adjustable main jet that Greg sent, and swap in a fresh set of rings to see where everything ends up. Time time time.
- Farfignugin
One thing I'd need on these are the downpipes from the exhaust to the chamber. It's not an easy piece to fab up from scratch, and stock exhausts are abundant for these.
