1987 Spree. Am I getting oil?
Posted: Mon Sep 30, 2013 1:24 pm
by indy111
I just put my motor back together with new bearings ,piston and rings and its running great. I rode it about a mile and I dont see any smoke. I did bleed the oil lines. When I first started it there was some smoke. After the test run there is none. Whats the easy way to see if oil is coming out of the pump. I pulled the oil line off the intake while it was running and I didn't see mush come out, maybe a drop in 30 seconds. Thanks guys.
Re: 1987 Spree. Am I getting oil?
Posted: Mon Sep 30, 2013 4:50 pm
by patthesoundguy
indy111 wrote:I just put my motor back together with new bearings ,piston and rings and its running great. I rode it about a mile and I dont see any smoke. I did bleed the oil lines. When I first started it there was some smoke. After the test run there is none. Whats the easy way to see if oil is coming out of the pump. I pulled the oil line off the intake while it was running and I didn't see mush come out, maybe a drop in 30 seconds. Thanks guys.
You did the right thing by bleeding the lines B-) the amount of oil that comes out of the pump is very small so that sounds about the right amount of oil. And your spree wont smoke under normal operation unless there is excess oil from somewhere
Posted: Mon Sep 30, 2013 9:21 pm
by paulpauly7
sounds fine to me but if your worried run a bit of premix in the tank as well for 1 tank
Posted: Mon Sep 30, 2013 9:28 pm
by indy111
Ok, thanks guys. I feel better now.
