Screaming noise coming from trans?
Posted: Wed Oct 02, 2013 5:32 am
by Meejacob
Hey guys so there's a noise coming from my trans that I just can't seem to figure out. I thought the problem was the bearings So I changed them out but still the sound is there. The gears I'm running are 7:1 Malossi straight cuts. Proper amount of oil is being used in gears. Af16 block. Any idea what it could be?
Re: Screaming noise coming from trans?
Posted: Thu Oct 03, 2013 6:47 pm
by maddog
an old belt or a stuck final drive pulley, take it apart and check the pins that ride the s-grooves if they bind the unit is shot = it needs grease every yr.
Posted: Fri Oct 04, 2013 12:35 am
by noiseguy
Is noise new, or did it happen at the same time as the gear change?
There's a reason most gears are cut helical... they are quieter. Straight cut gears are loud.
Posted: Fri Oct 04, 2013 8:36 am
by eliteguy50
Can you turn the gears by hand without binding? If so, noiseguy is right, you're going to have to adapt to straight cut primaries or switch to secondaries.
Posted: Sun Oct 06, 2013 9:14 pm
by maddog
Its simple- gears don't scream.
