I mainly don't want to add oil and have to mess with tuning. So I'm going back to bone stock.
I also have troubles with the threads on the block. I'm going to use timesert and recap them. I am planning on buying the M6 x 1.00mm set with a guide. When I do this should I do it with a drill? Free hand? I really don't want to mess this part up.
I also am going to install a brand new stock bore kit.
As far as electrical is concerned I will buy a new battery and see how that goes but am considering buying a new wire harness to see if that would help with electrical connectivity/ alternator charging the battery more efficiently.
The only mod I will consider is a rear spring from a ruckus because of my size 150lbs and the current spring's softness.
Any suggestions along the way would be nice. Also I need a stick air box in nice condition if anyone has one.i will post pics and build updates as well as a top end re-build video for anyone new that wants to learn a thing or two about working on Spree's.
