Page 1 of 2
inop speedo
Posted: Tue Oct 29, 2013 3:13 am
by TgyroX
Whats the typical failure with the speedometer drive gear ? My cable is free, took it off from the front wheel. Can see the flat tab that drives the cable, but it does not spin when the front wheel does.
1984 Gyro X
Re: inop speedo
Posted: Tue Oct 29, 2013 9:43 am
by martynkim
Typically the cable breaks. Can you make the speedo operate when you turn the cable?
Re: inop speedo
Posted: Tue Oct 29, 2013 10:31 am
by TgyroX
TgyroX wrote:...... My cable is free, .........
1984 Gyro X
I appreciate the response, but man, doesn't anyone read the original posts? This is the 3rd reply I've had where a comment is made that doesn't apply to the problem.
I hate to come off like a *, but come on.....
Yes the cable spins. My problem is the drive at the wheel is not turning
Re: inop speedo
Posted: Tue Oct 29, 2013 10:35 am
by swimmingfree
i dont see a question in it???
Re: inop speedo
Posted: Tue Oct 29, 2013 10:38 am
by noiseguy
There are only a couple moving parts in these. If not rotating, the gears are probably stripped inside. You'll need to remove it to check.
Re: inop speedo
Posted: Tue Oct 29, 2013 10:43 am
by martynkim
TgyroX wrote:Whats the typical failure with the speedometer drive gear ? My cable is free, took it off from the front wheel. Can see the flat tab that drives the cable, but it does not spin when the front wheel does.
1984 Gyro X
Yes you are coming off wrong.
You say that you removed it from the front wheel.
Im asking if it is functional the cable and the speedo.
A drive gear could be inside the speedo to a noob.
Noobs ask dumb questions sometimes and overlook the obvious so, I was asking a legitamate question.
:crazy: :b2t:
Re: inop speedo
Posted: Tue Oct 29, 2013 11:25 am
by bonesv
1984 Gyro X
I get the question. Pull the hub and inspect that the parts are all there.There's a bit of heat going on in there from the brakes being used which can displace the grease used to lubricate the worm gears. Over time, air and water can enter the hub and cause rust/seizure of the small shaft that turns the gear/speedometer cable shaft. Simply replace the hub if you can, or free-up the gear shaft, which is usually/possibly pressed in to the hub. Replace the seal and re-grease the gears. This is my experience from a limited standpoint. Wisdom shared here is subject to scrutiny but it does not change my experience. Good luck with the project. :eyeroll:
Re: inop speedo
Posted: Tue Oct 29, 2013 11:34 am
by swimmingfree
maybe im wrong but why do we need to tell him to open it up and look at it ???
swimmingfre
Re: inop speedo
Posted: Tue Oct 29, 2013 11:40 am
by bonesv
swimmingfree wrote:maybe im wrong but why do we need to tell him to open it up and look at it ???
swimmingfre
Aren't you busy working on your winter build Greg?
Re: inop speedo
Posted: Tue Oct 29, 2013 11:41 am
by swimmingfree
so are you saying keep out of this ????
Re: inop speedo
Posted: Tue Oct 29, 2013 11:42 am
by TgyroX
1984 Gyro X
Re: inop speedo
Posted: Tue Oct 29, 2013 11:45 am
by kingearwig
<chant> Jerry Jerry Jerry </chant>
Re: inop speedo
Posted: Tue Oct 29, 2013 12:01 pm
by LMH
"Use the search function or the google function" is one that people could have said, instead theyre trying to clarify whether you indeed did this or just saying you did. Instead of angering the people trying to help you be modest and take it as it comes.
Re: inop speedo
Posted: Tue Oct 29, 2013 12:05 pm
by LMH
You have a model that many of us are not familiar with, and the ones that do have TG50s are usually very good with them. Im leaving mine in the back of the garage because Im not versed in them at all. I abhor thinking about the day my gyro doesnt start, run right or even the speedo cable breaks.
Re: inop speedo
Posted: Tue Oct 29, 2013 12:42 pm
by TgyroX
noiseguy wrote:There are only a couple moving parts in these. If not rotating, the gears are probably stripped inside. You'll need to remove it to check.
Thanks Jason, I've looked in the service manual but its not much help. Seems the whole manual only tells you how to take things apart, and a few torque specs.
I'll dig into this situation once i have it starting and running reliably. Are the components for that system still available ?
