Battery sa50
Posted: Wed Oct 30, 2013 9:23 pm
by 12gauge
So I'm running a 10in radiator fan were seat bucket use to be. And like I new it would it killed my batteri. It's on a toggle switch and direct circuit to battery If I use a car battery will this moped charge it and. Would to many cranking amps burn up my wire harness or starter
Re: Battery sa50
Posted: Thu Oct 31, 2013 6:05 am
by paulpauly7
What is the fan for ??????????? do you have a gassy behind ???
Re: Battery sa50
Posted: Thu Oct 31, 2013 12:54 pm
by cruzingratiot
sa50 max amperage from charging system is 4.0 amps
you need to calculate the amp draw
of the fan you have and headlight taillight dash lights ignition system
and if the total draw dosent exceed 4.0 amps you are ok
if it draws more than 4.0 amps no matter what battery you put in it will not charge
12gauge wrote:So I'm running a 10in radiator fan were seat bucket use to be. And like I new it would it killed my batteri. It's on a toggle switch and direct circuit to battery If I use a car battery will this moped charge it and. Would to many cranking amps burn up my wire harness or starter
Re: Battery sa50
Posted: Thu Oct 31, 2013 2:47 pm
by 12gauge
Fan for motor cooling and d*** what could I do to charge car battery
