Honda spree engine swap, no weld?
Posted: Thu Nov 21, 2013 7:34 pm
by appleboy64
Hello again, thanks for all the help on the last post, I am back with another question.
I have been looking around and it seems that an se50 engine swap into the spree is not extremely complicated, just some parts to buy and a hole needs to be drilled.
If I was to do one of these se50 enigne swaps, what mounting parts and such would I need?
Also, if I were to do an se50 engine swap about how fast would the new modded spree go?
Final question, doubt it is even possible as it is much larger but has anyone tried putting something like an elite 80 engine in a spree?
Re: Honda spree engine swap, no weld?
Posted: Thu Nov 21, 2013 8:07 pm
by martynkim
viewtopic.php?f=16&t=28653
Or just a little way down the page.
Posted: Thu Nov 21, 2013 8:36 pm
by bfowler
There's also a thread stickied at the top of the build section that is about a spree to se50 swap.
Posted: Thu Nov 21, 2013 9:09 pm
by appleboy64
I saw the stickied post in the build section however I had a couple questions about it,
I saw this list
se50 or dio rear wheel (not sure if thy are interchangable
se50 or dio brake cable
se50 or preferably a dio carb
a new kickstand
6" 5/16 bolt and 10 or so washers that fit real snug and a locking nut
somthing to use for a shock mount 1 1/2 inches off the frame by the voltage regulator
so i was wondering if i really needed all of this or its just recommended, i only ask that because I have seen motor swaps mentioned as you just take out the old mount put a new one in, put on the new motor, wire the wires by color and reposotion the suspension.
However all this makes it seem more complicated
the questions i have are, do i really need a new wheel and kick starter and why does it mention getting a carb shouldnt your engine come with one? Also why the brake cable?
Posted: Thu Nov 21, 2013 9:33 pm
by spreeinkc
Well...
Brake cable won't reach so you'll need a longer one.
Not all engines will come with a carb. (or a rear wheel) Will be handy if it does!
Kick stand will be too short after motor swap and with the larger rear wheel and tire so the scooter will fall over unless you modify it or get a bigger one.
Not sure what the bolt and washers are for b/c I haven't read the thread but I'm thinking of doing one now as well if I can find a se50 mount.
Posted: Thu Nov 21, 2013 9:39 pm
by appleboy64
I'll be on the look out for a mount as well so if you find one leme know haha
Posted: Thu Nov 21, 2013 9:45 pm
by spreeinkc
I have a few questions for the experts though...
All it refers to is the se50, I assume that means a engine mount from a 88-93 sa50 won't work?
Is the engine different as well? I thought the later Aero's, se50, & early sa50's all used the same af05e?
Posted: Thu Nov 21, 2013 11:01 pm
by paulpauly7
sa50 mount is different to se50 .The se50 mount just needs to be trimmed .The factory stand will not fit with this mount setup .Aero af05e has a 4 bolt manifold and a 2 bolt manifold.The 4 bolt is better just because its easyer to fit upa aftermarket manifold and carb.You need a se50 or sa50 rear wheel they are interchangeable if you didnt get one with your motor a spree wheel wont fit a variated af05e
Posted: Thu Nov 21, 2013 11:23 pm
by spreeinkc
Cool. So then, case wise, any af05e will work? I have several af05 engines I just wanted to make sure they were all basically the same.
Posted: Fri Nov 22, 2013 12:18 am
by paulpauly7
so long as they are variated
Posted: Fri Nov 22, 2013 2:25 am
The un-restricted version of SE50 came with the tallest stock gearset of any AF05's and AF16's.
It gave about a 9% overdrive from other models. One member upon finding that out said - 'so that's why my brother's SE50 always beat me on my Aero 50'. With SE50 gears, a guy can state his powertrain is 100% Honda, yet has a sleeper
We've compiled transmission gear sets at the link below:
Wiki Link
Posted: Fri Nov 22, 2013 3:53 am
by spreeinkc
That's funny because I saw that page that showed all the gear ratio's and saw it was different than all the rest but never put two & two together that that's why my se50 is the fastest out of all my hondas. (still not faster than my Jog though) Gears are next on my list though!
