Gy6 150 simple harness info please
12gauge
Post by 12gauge »
Someone please post good layed out pic of this harness or simple diagram of how to wire gy6 150 to run and have electric start that's it please help I know none of you care about 4t s*** but I know a lot of you are good with these things Chopin harnesses for racing or drag
Re: Gy6 150 simple harness info please
Simplified diagram from Yerf Dog 150cc GY6 ATV. It would be a good idea to double check with your own GY6 electrical diagram.
Original Yerf Dog diagram
-- Pictorial ignition connection diagram from the 'net
12gauge
Post by 12gauge »
Sorry about that was going on house arrest and wanted to figure out ASAP. So does the yellow go to positive on battery for trickle charging or white ?
Scroll up, the un-modified "Yerf dog" diagram does just what you want --
  • E-start
  • Battery charge
  • Ignition
Connect both the yellow and white wires to the regulator per diagram. Omit the "LIghts" and "Choke" + Resistor from the diagram if still being minimalist.
Yet if it's a daily driver below 70 degrees or so, leaving the "Choke" (Bystarter) and resistor in will still be clean looking. All all components can be nearby the engine/stator.
12gauge
Post by 12gauge »
I am gettin oko 28 with pull choke
