Malossi CDI
LMH
Malossi CDI
Post by LMH »
I finally had some long distance trials for the Malossi cdis. I report they work exceptionally well. Great power and it may have been the fact I didnt need to full throttle all the time but I actually got better MPG. Much faster start up than with stock or the masses of "performance CDIs" that are being sold. On top end with the stock set up in full tune I gained maybe 2-4mm further on the cluster than with any other CDI. Although the engine didnt sound as loud at the top speed like before. It just sounds and acts so much more healthy than with the other cdis Ive tried. There are 2 versions of the CDI as Keith and I found out. One requires modifications and the other is direct plug and play. Both work equally well. The plug and play has an accessory also for timing control if you decide to purchase it as well.
This is the one that requires you to modify or make an intermediary harness to work on the Elite 89-01. Also you need a knowledge of the af24-28 wiring.
LMH
Re: Malossi CDI
Post by LMH »
If time permits Ill do some timing charts with the various CDIs or I can let MW take a stab at it if hes so inclined. I feel hes well educated in the electronics field, more than enough in my opinion.
If I can find the pictures for the stock plug and play CDI Ill post it as well, or Ill pull it off the bike to take a pic or 2. It is a direct plug and play with absolutely no rev limiter so be fore warned.
LMH
Re: Malossi CDI
Post by LMH »
Finally decided to install one of the TTO tach I received from Graphite and found out Im spinning some high revs when losing the needle. I thought I was hauling some rear. Stock cylinder cant possible have more in it.
Re: Malossi CDI
Post by swimmingfree »
boy nice rpm you rolling there guy...
LMH
Re: Malossi CDI
Post by LMH »
All bolt ons only. 100% stock block, cylinder, and gears. Its never been opened on either end.
Re: Malossi CDI
what your top speed on that little scremer???
paulpauly7
Re: Malossi CDI
Post by paulpauly7 »
how much are these cdis?
Re: Malossi CDI
like to no what your max rpm was with the stock cdi was??? as well as the temp????
LMH
Re: Malossi CDI
Post by LMH »
Ill give her another whirl when it goes above 40 again to get some stock numbers and temps to compare. I brought the GPS but she died shortly after I took off. I know its scooting along pretty good. List of mods.
Stock never touched block and cylinder+head-- 1999 Honda af16e
NGK BR8HSA plug-- Oreilys
Koso orange "Hi performance" coil-- Racingplanet
Malossi plug and play CDI-- Redeft
Polini Air Filter for 94-01 sa50 coated with Maxima filter oil for cotton and foam filters -- Some eBay user from the UK and spray oil from dealer
Stock air box with 2nd tab modified with exacto blade -- Harbor freight for exacto
OEM Honda 87.5 Main Jet needle in middle position (stock rung) --local stealership
Polini CF reeds that come with Polini Corsa cylinder kit (finally got to use one)-- Veedubh for the corsa kit
PG short -- VTCycles
Polini variator with Malossi ramp and 6 Polini 7.8g race rollers -- Daywot for polini vario --Redeft for malossi ramp-- racingplanet for rollers
OEM Honda belt for 94-01 SA50 af16e
Malossi Yellow rear contra spring -- Redeft
Malossi Delta clutch set to soft -- Redeft I think
Malossi winged clutch bell (I believe this has something to do with being able to maintain the higher speeds as it is heavier than stock with the winged cooling fins) ---- S4patrick
Stock gears with Honda GN4 10w30 filled till it comes out while upright. --- Honda dealer
Stock IIRC size tires -- OEM Honda
Open rear cover
Trail tech TTO tach --Graphite9
Trail tech TTO Temp gauge -- Graphite9
Oil pump block off plug --- VT cycles
Premix 93 octane with 32:1 maxima 927 castor
Red Eft Performance
Re: Malossi CDI
Post by Red Eft Performance »
Nice im glad to hear it!
Red Eft Performance
View products click => Here
