What is the Difference between an af27 and af28?
Posted: Fri Dec 27, 2013 2:25 pm
by Dakine
Ive been looking at pictures and looking all over online and I cant find much... and ?I Was trying to look on here to find the codes/numbers for all the bikes. ... Ive been ordering alot from the japan auctions but right now im gonna start ordering Super Dio stuff..
NEVERMIND SANJURO CLEARED IT UP FOR ME.. Thanks
Re: What is the Difference between an af27 and af28?
Posted: Fri Dec 27, 2013 2:58 pm
by Downsouthdio
I think the af28 is the super dio
Posted: Thu Jan 30, 2014 11:14 pm
by S4Patrick
Hey, post up the differences between the AF27 & AF28!!!
Posted: Fri Feb 07, 2014 5:58 am
by Munstah666
Af27 and af28 are both Super Dios but the af28 is called Super Dio ZX which comes with front disc brake, yellow headlamp and rear LED spolier, other than that both are identical. There is also an SR version, comes with front disc brake, white head lamp and rear luggage rack instead of a spoiler. Hope that helps.
Posted: Fri Feb 07, 2014 5:59 pm
by LMH
Block wise only difference is what year it was produced. What did sanjuru have to say about them? Hes definitely more on the up and up with the variances than most of us. Munstah has some cool stuff as well.
Posted: Sat Feb 08, 2014 12:44 am
by sanjuro
Munstah has got the main things down.
Additionally,
-forks are upgraded on the ZX
-better rims
-different steering tree
-more aggressive cdi
-slightly different wiring harness
-small variance in frame detail
-ZX models had unpainted fuel tanks
-different exhaust
-different speedo gauge
-different stator
-ZX transmission with larger diameter shivs
-longer drive belt
Posted: Sat Feb 08, 2014 3:20 pm
by paulpauly7
now i agree with all of what sanjuro wrote but not the cdi i have a af27 cdi and a af28 zx cdi and both are the same .also the same cdi in my jap niftyfifty (spree) all have the same part number.
Posted: Tue Feb 11, 2014 1:04 am
by sanjuro
The CDI on the af27 is usually smaller in physical dimensions. Maybe you have the Dio SR CDI?
Posted: Tue Feb 11, 2014 3:22 am
by paulpauly7
definitly dio zx af28 bought it in japan .Even a honda pal i have has the same cdi .Its a jap pal with the spree motor but with a 3 roller variator .
Posted: Tue Feb 11, 2014 11:07 am
by sanjuro
Post a pic of your CDI. I'd like to see which one you have.
Below is a pic of a Super Dio ZX af28 cdi. It should have the two connector plugs on the underside.
