Leaky Flanges (We don' need no STEENKIN' Flanches)
Posted: Mon Dec 30, 2013 2:41 pm
Paraphrased from the Treasure of the Sierra Madre.
So I was replacing my weather-checked 2008 Pirelli last weekend. Removal of the seat bucket revealed the unsightly oil-spray indicating yet another exhaust flange leak. I thought I'd fixed that with a new gasket and careful torque wrench application, but the mist was undeniable. I think I found why:The pic shows the PG Short flange after about 15 minutes of sanding with a dead-flat block. The bright spot at the rim of the exhaust header - see around 11 o'clock - represents a high spot, probably welding schmutz. The dark is a recessed patch of the flange. What I think happens is that the material distorts just a little when they robot-weld the flange to the pipe, and for the cost they get per pipe they don't bother planing that back flat at the PhonGeer factory.
Re-installed, but it'll be a few days before I find out if Flash has regained continence of its Precious Scooterly Fluids.
That one was paraphrased from Dr. Strangelove...
