I have noticed that when it sits for more than a week or so, it takes a very long time to start. Like 6 or more 8-second pulses on the starter. Has anyone else noticed this with Arreche's, maybe they are vented more and the fuel evaporates out of the bowl faster? If I ride it everyday it fires up first try every time. I am considering a check valve on the vents, don't know if this would be effective or not...
Arreche carb hard starting
Hey guys, I have been so busy I have not put many miles on my little Aero 50 (setup: arreche 19, Malossi cast iron 65cc, Boyesen reed, LV SP3) Too many rides in the garage to choose from
87 Elite 50
99 Aprilia SR50 Carb polini
1973 Suzuki TS185 smoker!
2002 KTM Duke
2002 KTM Duke
Re: Arreche carb hard starting
Are you using the choke on it? My 19 had to be choked or it wasnt starting. It was quick to flood the cylinder. I really liked the bottom end with the 19. If youre using one of those "racing" cdis I would try swapping back to the stock cdi and see if that helps also. Those blue cdis have a huge initial advance and make it hard to start on a 2 stroke.
my arreche does the same thing after a few days sitting. But my stock keihin did that as well, but probably took a few days longer to evaporate. The cure is to ride more often.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
Ride more is the cure for a lot of things!
