deaf ears 180ks..... - re-name green splot
Posted: Wed Jan 15, 2014 5:46 am
by Breezy
27-4 - Edit - Removed drunken babble
Re: deaf ears 180ks.....
Posted: Thu Jan 30, 2014 12:26 am
by Breezy
^^ I probably shouldnt post after having a few Lol.
a start
Bare metal
drenched in rust converter
Re: deaf ears 180ks..... - re-name green splot
Posted: Sun Apr 27, 2014 3:59 am
by Breezy
I got tired of waiting 3 months for my engine to be sent to me that I paid in advance for, so jumped on this below when I saw it.
Simple clean of the carb and fixing/bodging up some wires got her going first pop sounding smooth and quiet
As an update the frame has been painted green, fairings black with green ascents.
Will post pics of that later in the assembly, its painful to upload at the moment
Then for $40 grabbed this pile of goods, score!, purchased it without seeing it and to find there is like 2.5 scooters there.
Some bits I have been making
A clone 19mm dellorto sitting on a home made manifold, the reed cage I will probably change for something else.
Enough space to clear shock, hoping will clear fairings too
Made an intake pipe with some leftover fibre glass and vinyl ester resin (good fuel resistance).
Hoping it should keep the filter from getting too much fuel soak, might shorten it pending the fairing clearance, going to make a bracket to take the load off the carb too.
Next to make the exhaust/chamber and look at swapping the cylinder head with the SB50 engine and NQ50, the oil pump driveshaft has been removed ready to run premix
Posted: Sun Apr 27, 2014 6:11 am
by paulpauly7
just grind the teeth off the shaft then reinstall it .complete removal of the shaft means lower case pressure meaning less power to push the fuel up to the top of the cylinder
Posted: Mon Apr 28, 2014 4:28 am
by Breezy
paulpauly7 wrote:just grind the teeth off the shaft then reinstall it .complete removal of the shaft means lower case pressure meaning less power to push the fuel up to the top of the cylinder
Good point, was going to make an alloy bung, will take that concept into consideration if I go that path, I would have lost a little bit from the Manifold to Reed, but wouldnt be much more or less than a dio chrome ct
Posted: Mon May 05, 2014 3:34 am
by Breezy
Seat done - before and afters
Test fit
need to shorten adjustment screw and the air intake pipe I made
well it fits in there, just needed to make a small spacer on the engine side of engine mount, about 10mm.
Playing silly buggers, sacrificed a rusty set of front forks for the sheath
split into 2 pieces
have placed into the front shocks to lower an inch, dont think they will stay in there though, will probably remove them.
just a pic of the wheels, took down to bare metal, rust converted then painted
Looking at making this into an internally sprung side stand
Posted: Mon May 05, 2014 8:35 am
Great work so far! Drip-drip-drip; the sound of American Spree owners drooling at the thought of a variated Spree.
Posted: Mon May 05, 2014 2:20 pm
by paulpauly7
those engines are everywhere here .I have a pal with the variated spree motor lieing behind my garage .
Posted: Mon May 05, 2014 3:10 pm
by Dio89Elite
Green accent color scheme is cool.
Thanks for sharing! Love them pics!
