Page 1 of 2
BREAK-IN question
Posted: Mon Jan 27, 2014 7:29 pm
by 77 vega kammback
i bought my 94 sr for 100 bucks and had to rebuild the whole motor i bought a new piston but bought a used jug would i still have to treat it like a normal break in or will it be a re assemble and go
Re: brake in question
Posted: Mon Jan 27, 2014 8:28 pm
by bonesv
77 vega kammback wrote:i dought my 94 sr for 100 bucks and had to rebuild the whole motor i bought a new piston but bought a used jug would i still have to treat it like a normal brake in or will it be a re assimble and go
Yea, you have to seat the rings. Go easy for a tank or two with maybe two cap-fulls of 2-stroke oil added to the gas tank.
I hope you honed the cylinder first?
Posted: Mon Jan 27, 2014 8:32 pm
by paulpauly7
the bore will need to be honed and you need new rings .And yes it will need the break in slowly .never fit new rings to a old bore without honing it out .
Posted: Tue Jan 28, 2014 2:17 am
by 77 vega kammback
witch would you recommend for the job a wire honer ball honer or a fingered honer from my reading there seems to be conflict between them keep in mind ive never done this before but ive got a spare jug to practice on before i try it on my good jug
Posted: Tue Jan 28, 2014 11:00 am
by swimmingfree
step 1 is to start the motor and let it heat up slowly (at a idle ) a fue times to running temp about 5 to 8 times..
then go for short run about 3 to 4 miles not a wide open let it cool down... as for the oil in the tank i run 64 to 1 in my first fue tanks ( 2 oz per gal ) take it ezey on it for the first 100 miles no wide open ..
Posted: Tue Jan 28, 2014 11:04 am
by breaze
Check the section in this Wikispreedia write-up about honing the cylinder - it recommends a ball type hone:
http://hondaspree.net/wiki/index.php5?t ... eplacement
Posted: Tue Jan 28, 2014 1:27 pm
by otto-man
I've tried both brake cylinder hone (3 pads) and a ball hone (thanks Noiseguy) and I really prefer the ball hone. Keep the cylinder and hone wet with honing oil, 10w30, wd40, etc. and be sure to CLEAN thoroughly before reassembling.
Posted: Tue Jan 28, 2014 4:45 pm
by 77 vega kammback
thank you all for your help
Posted: Tue Jan 28, 2014 6:00 pm
by ped
hi vega. use what you have. will the ball hone get stuck in the ports?
Posted: Tue Jan 28, 2014 6:14 pm
by 77 vega kammback
ive got a brake cylinder hone will that work
Posted: Tue Jan 28, 2014 7:26 pm
by maddog
sounds like you have a stock cylinder, you can hone and ride easy for about 100 mi.
Posted: Tue Jan 28, 2014 7:30 pm
by bonesv
77 vega kammback wrote:ive got a brake cylinder hone will that work
Probably too small for the 39mm stock cylinder. Amazon.com has the ball hones, under the name "flex-hone", in the size you need.(always get the size a mm or two larger) I think they were $10 bucks.
Use a slow speed cordless drill with the cylinder upside-down over a plastic bowl small enough to support the cylinder. Use some 2-stroke oil to lubricate it and make sure you give it even strokes in and out. 20 passes in and out is plenty. Directions are on the package lol.
Seating the rings is important. Please take the time to "google it" and educate yourself so you will only have to do this once.
Happy Trails!
Posted: Tue Jan 28, 2014 9:19 pm
by 77 vega kammback
i did not use rtv i spent a little extra to get real gaskets it pays in the end to do it right the first time ,
its all together and running im running 64 to 1 premix for the brake in and then i think 32 to 1 after (im premixing cause the oil pump was fried witch explains why it seized up on the previous owner and he didnt know y it stoped running and when i split the case the crank was snapped in two id post but i cant figure out how to resize
Posted: Tue Jan 28, 2014 9:20 pm
by 77 vega kammback
i replaced all seals bearings and gaskets
Posted: Tue Jan 28, 2014 10:17 pm
by bonesv
Did you say 64 to 1 premix? That ain't gonna work! Go back and adjust it to 32 to1 or you will be rebuilding it again. Where did you get another crankshaft from?
