Carb tuning 85 spree
Feelingspree
My 85 honda spree is not running as it should. It runs OK when I tape the air intake shut about 75%. What could be causing this. I'm thinking it might be the auto choke not working properly.
- martynkim
Re: Carb tuning 85 spree
Is the air box installed? If so, does it have a good filter inside and is it sealed properly? These are all things that can cause your issue.
Feelingspree
Airbox is installed with new filter and is well sealed.
- swimmingfree
what is the gap on the plug??? set it at 25... give more info on how thing going...
Feelingspree
The plug gap is at 28 right now. It will run perfectly for a few seconds to a minute or two then it will lose rpm's for a minute or two then right back again but, that is only with the intake holes taped at about 75% closed. All this is happening whether under a load or not.
Feelingspree
And I will reset the plug to 25, haven't done it yet, Will do that this evening. It's cold and rainy here in Texas so putting it on the street is an everyday "maybe thing" for the time being.
Feelingspree
OK installed new plug gapped at 25. Runs better but still needs intake closed 50%
