spree dio burnout
- paulpauly7
spree dio burnout
im still trying to work out how to post videos from my ph but if you search Spree dio burnout on youtube and scroll down a few videos and you will see me at our yearly musclecar madness show on the burnout pad .I thought id give the crowd a break from monster v8s .When ive worked out how to post fom my ph ill link it here
Re: spree dio burnout
Just copy and paste the youtube link in.
Honda DJ1R project
Honda DJ1R project
Honda DJ1R project
Honda DJ1R project
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
- paulpauly7
i have a few spare tyres .I didnt use my michelin s1 .Thanks NZ honda but theres a better video uploaded by me user name Spree dio
Hi paul. very nice burnout. lots of power. the blowout was the cherry on top.
- paulpauly7
i wasnt stopping till it popped .It was hard to keep the front wheel from moving too much old rubber all over the pad and the back tyre just wanted to grip.Good fun tho ill be back there next year with more tread on the tyre
paul your belt may be gone too. give it a check.
- paulpauly7
nothing wrong with my belt im running the malossi zx belt
Must take alot of $$$ to get a 4 stroke to burn rubber, anyway invest in crank bearings cuz they go real fast doing burnouts!
Nice Paul.. Love the nifty50 headlight. What frontend are you running ?
- swimmingfree
Sweet!!!!!
- paulpauly7
dio zx front end with a custom made front fender.Ive got a 220mm rotor and caliper spacer on the way from japan
Can you even do a normal burnout on a Stock Spree or is an engine swap an absolute must?
I can burnout, but I'd need someone holding the front end or back end so I spin but dont move. I've done some burnouts out of gas stations, but it was started on the kickstand.
