Page 1 of 2
wont stay running, no power PLEASE HELP
Posted: Sun Aug 20, 2006 8:10 pm
by sirbikealot7
ive got an 86 spree and it will not stay running for more than a minute, ive cleaned the air filter and was going to do the gas filter but i dint know how to get it out, i adjusted the screw on the side of the cabourator properly to 1,1/2 turns out, i cleaned the plug, and took out the crankcase oil, which now i do not how much put to put back in or if i should stick it back into the same place it came out of, and i dont have a battery in it. i think it might be the automatic choke stuck on or something, i dont know. any help would be appreaciated. thanks alot
Posted: Sun Aug 20, 2006 9:58 pm
by myhonda
clean that carb. clean it very good.
Posted: Sun Aug 20, 2006 10:43 pm
by sirbikealot7
ok what do you reccomend to do it with, i.e. what cleaner. seafoam?
Posted: Sun Aug 20, 2006 10:54 pm
by sirbikealot7
and also instructions on how to do it. im only 15. thanks so much
Posted: Sun Aug 20, 2006 11:02 pm
by MySpree
loosten your exaust, i think you have a clogged exaust.
Posted: Mon Aug 21, 2006 12:33 am
by sirbikealot7
ok i'll try that. but i still need help on the crankcase thing
Posted: Mon Aug 21, 2006 1:00 am
by MySpree
fill it wiht transe oil, and let it sit, put a container on the side and let the exsess come out the hole that you drained it from, then you just put the bolt back in, or ou know you could always go to the tec docs, adn download the spree service manual, were they give y ou step by step instructions
Posted: Mon Aug 21, 2006 1:12 am
by sirbikealot7
ok thanks
Stalling
Posted: Mon Aug 21, 2006 2:47 pm
by CudaDon
Pull off intake and check reed valve for damage or carbon holding one or both of the valves open.
Don
Posted: Tue Aug 22, 2006 1:47 am
by sirbikealot7
ok so i cleaned the carb with the pyrol carb cleaner by inserting it through the screw hole, i followed the instructions on how to clean the carb that way. and now the spree will run but not without gas or it dies, and it will not go past 15 mph not matter what, and usually wotn make it past 5. im not as big guy. 150lbs so that shouldnt be the problem. i dont know. any help?
Reed Valve
Posted: Tue Aug 22, 2006 9:26 am
by CudaDon
Did you check the reed valve??
Posted: Tue Aug 22, 2006 12:06 pm
by sirbikealot7
no where would that be at. and how do i go about removing it and cleaning it? could this be a fuel filter?
Posted: Tue Aug 22, 2006 12:46 pm
by -aL-
theres a carb... that connects to the intake manifold, on the other end of the intake manifold, are the intake reeds, theyre between the intake manifold and the engine
Posted: Tue Aug 22, 2006 5:46 pm
by MySpree
deid you losten the exaust? sounds like when i got my firsr spree had the same probs barley fired, had no power nad went 15, sometimes 16, it was a clogged exaust
Posted: Tue Aug 22, 2006 6:48 pm
by sirbikealot7
yeah i took the exhaust off but i didnt really know how to clean it, so i re installed it
