ImageShack
ImageShack
Post by swimmingfree »
ImageShack is not working for me or shood i say its smarter then me ... if some one cood help me out by telling me how to use ImageShack or send me to another spot to use to post photo i will ever O you one ....i just swich from xp to vesta if that helps and still lost on it ...
thank you for your time...
Dr_Craw
Re: ImageShack
Post by Dr_Craw »
you can always use imgur but it doesn't resize pictures.. (but the interface is realy easy, just drag from your computer and drop onto the website)
Roll the dice
Re: ImageShack
this is the best i con do with imageshack
https://imageshack.com/i/jj4hz4j
Dr_Craw
Re: ImageShack
Post by Dr_Craw »
is this what your trying to do?
img]https://imagizer.imageshack.us/v2/300x4 ... 3/4hz4.jpg[/img ?
to get the link properly
right click on the image you want to paste and select copy image url
then paste inside a section that says {img} http...url {\img} (note using square brackets)
Roll the dice
Re: ImageShack
https://imagizer.imageshack.us/v2/117x1 ... 3/4hz4.jpg
yes that what im trying too do... lets see if it work for me the photo is just some bull...
Dr_Craw
Re: ImageShack
Post by Dr_Craw »
you need to put that link inside the tags
{img} ......link....{/img}
but use square brackets
Roll the dice
LMH
Re: ImageShack
Post by LMH »
Why dont you just use photobucket? Its free and works great. I can help you set one up if you need greg.
Re: ImageShack
ok got a photobucket put a photo on it then try to post the photo with no luck ...and yes it me in the photo...
ps
all 3 photo are the same...
http://i1201.photobucket.com/albums/bb3 ... icture.jpg
http://s1201.photobucket.com/user/frees ... sort=3&o=0
http://s1201.photobucket.com/user/freeswimming/library/
Re: ImageShack
You are just about there -- From your photobucket page - see below:
A) Copy the text in textbox labeled "IMG" and paste into this site's message editor.
B) Make sure the "Disable BBCode" check box on the message editor is *not checked*
Here's the result:
Re: ImageShack
thank you big guy ...yes these are my photo and my art work...
