We need a larger fuel cell
Someone has had to of came up with something. I use the kymco zx50 fuel tank which is only slightly larger, and only seems to fit if the oil tank is gone. Id like a fuel cell the size of my under seat compartment with out putting a fuel cell inside. I had one inside a 89 bucket and wasnt satisfied and didnt pursue it further.
Id like to get one that doesnt look all jacked up or obviously done with half a thought. Any ideas or pre existing products?
Re: We need a larger fuel cell
HI LMH. what do you ride?
I like to do the same with my spree. I may try a 86-87 aero tanks and seat.
you can go custom , but that's big bucks. get a goped gas tank? go kart gas tank...LoveMyHonda wrote:Someone has had to of came up with something. I use the kymco zx50 fuel tank which is only slightly larger, and only seems to fit if the oil tank is gone. Id like a fuel cell the size of my under seat compartment with out putting a fuel cell inside. I had one inside a 89 bucket and wasnt satisfied and didnt pursue it further.
- paulpauly7
I have a mate who makes intake manifolds and surge tanks and all sorts of alloy stuff ive spoken to him and have given him some measurements to build a custom tank for my spree.Id like it to drop down the sides of the frame and fill up the hole where the oil tank was .You know how it is he has so many jobs on but it is in the works
For an aero without the oil tank you can custom extend the fuel tank or go to a smaller carb or change gears.
Thanks MD
I have seen an under-the-seat aluminum aux. tank for Dio on webike but I dont know how it would work with the elite tank hooked up to it also. There's not a lot of room underneath the bucket to run fuel line, petcock, etc. It says 4.8 litre capacity!!!
http://japan.webike.net/products/9678105.html
http://japan.webike.net/products/9678105.htmlLoveMyHonda wrote:Someone has had to of came up with something.
Heeeeeeeyyyyyyy, ones 10 cents more. Whatre theyre tryin to pull here?!
Hopefully it fits because Im ordering it.
Either you or me, so I guess I'll get some kick stands then. and some brake levers.LoveMyHonda wrote:Hopefully it fits because Im ordering it.
Kevinstonge
I'm planning to do this in the spring. Extending the tank back ~3-4", and moving the battery back as far as I can.maddog wrote:For an aero without the oil tank you can custom extend the fuel tank.
Pineapplegti
Id be in for a couple... I always carry a backpack full of smart water bottle aux fuel tanks when I am running lol..paulpauly7 wrote:I have a mate who makes intake manifolds and surge tanks and all sorts of alloy stuff ive spoken to him and have given him some measurements to build a custom tank for my spree.Id like it to drop down the sides of the frame and fill up the hole where the oil tank was .You know how it is he has so many jobs on but it is in the works
