Stroker build setups - moved from Builds
Re: Fab Flash 7: Fabrizi 50mm Cylinder Kit
I had a 30 OKO on a 90cc ministroker once. Ended up 60/160 as I recall. You probably need more. New belt on the way for Flash 7. Thinking of 155 with needle down a notch from center to test next.
Downsouthdio
Post by Downsouthdio »
Im using a real small main jet on my 120..its with a 28mm and big scorp
Honda super dio
Corsa
26mm
Sparrow
