Quest for disk brake
paulpauly7
Re: Quest for disk brake
Post by paulpauly7 »
are they KN shocks
paulpauly7
cheap but they work well i have some in gold .I have a mould to make front fenders to fit them shocks/setup .
NZHonda
Post by NZHonda »
Wow nice work. I am loving the disk setup on my ZX Dio. I do need another set of Dio alloys though! What would be the cost of your setup?
Honda DJ1R project
Dr_Craw
Post by Dr_Craw »
im def, interested in the final product.
Roll the dice
cruzingratiot
Post by cruzingratiot »
just courious what is the spacing fork tube to fork tube centerline
10 mm axel or 12 and can you get the speedo parts
thank you
Paul
Donate Life
http://www.donatelife.net/
Thank You
deuce217
Post by deuce217 »
I am also always wanting to make this happen. I was trying to engineer a bolt on for the stock forks but have ran out of time and room in my shop. Someday, I am definitely curious to see what you come up with. Thanks
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
NZHonda
Post by NZHonda »
I am using the standard master cylinder that comes with the ZX. I believe they are all the same for the Dios. I have been mixing and matching between AF28 and AF34(late model dio with horizontal motor). On the back of the master cyl it has a set of numbers that give piston size and stroke etc I think. I have a spare one I can photo graph and get some numbers for you if you want.
Honda DJ1R project
LMH
Post by LMH »
My friends use the kymco zx50 MC for their NCY front disc swaps. Readily available and works great, I believe their even a little oversized.
alexfleury
Post by alexfleury »
I'm interested in this topic too. I am working on a BBK bike that I plan to take on some real curvy roads and I am pretty sure I will need more brakes.
Life May Not Be
The Party We Wished For
But While We Are Here
We Might As Well
Dance
W8kbrder
Post by W8kbrder »
Any updated pictures of this?
2001 Honda Elite S (De-restricted)
|Prodigy Variator w/ 9g weights|De-restricted Exhaust|Oil Pump Delete|1.5k Center Clutch Spring|2k Clutch Grabbers|.88 Main Jet|2nd Airbox Tab Removed|9:1 gears|49mph GPS confirmed|
LMH
Post by LMH »
Which tree do you have to use?
