AF16 and kymco sc10as flywheel lightening and balancing
LMH
Post by LMH »
It was performed by Denny Mears at Flotek Performance out of Pa. He built a chuck to do our flywheels if anyone is interested. I believe it was 40$ a flywheel you pay chipping both ways. You can send him your FWs or let me know prior to it and I can set it up. Either way hes a wonderful person to deal with.
Top zx50 bottom elite af16
Kymco zx50
Honda elite af16e
If youre ever curious as to if a sc10as (or vice versa) stator and pick up will work on an elite look at the flywheels wood ruff position. Direct relation to timing.
ped
Re: AF16 and kymco sc10as flywheel lightening and balancing
Post by ped »
Hi LMH.
will the flywheel stay balance? after cutting?
thanks.
LMH
Post by LMH »
Yes, he does many different fws cut and balanced.
paulpauly7
Post by paulpauly7 »
any difference in performance ? revs cleaner? smoother?
Dio89Elite
Post by Dio89Elite »
nice. I've actually been looking at this option as I know someone that does the same thing here locally (Oahu, HI); which is why I can vouch that this is a pretty good deal. :thumbwink: Thanks for posting. :)
I just need to find a spare flywheel... so I can still ride while I wait... :coolcruise: :mrgreen:
paulpauly7
interesting on the kymco the key way is oppisite the pick up strip but on the af16 its offset .My af18 is the same as your kymco flywheel .I wonder what the timing differences are between the jap af18 vs af16?
LMH
Post by LMH »
Zero difference in timing. It's the location of the pick up that keeps them timed. If there was any difference in timing cylinders would not be interchangeable.
LMH
Post by LMH »
Also the pick up is the easiest way to modify timing, you elongate the holes.
paulpauly7
whats the weight difference between your stock and lightened ?
