I had already put in an 85 main jet. So I did a trial run. Got 380-390 with a max temp of
NOT GOOD
So I ordered this drill bit set from Amazon
http://www.amazon.com/Forney-60239-Mini ... ll+bit+set
And I found this chart about drill bit sizes compared to measurement of inches and mm
0.7 mm
0.0276
0.7000
#70
0.0280
0.7112
#69
0.0292
0.7417
#68
0.0310
0.7874
1/32 in
0.0313
0.7938
0.8 mm
0.0315
0.8000
#67
0.0320
0.8128
#66
0.0330
0.8382
#65
0.0350
0.8890
0.9 mm
0.0354
0.9000
#64
0.0360
0.9144
#63
0.0370
0.9398
#62
0.0380
0.9652
#61
0.0390
0.9906
1 mm
0.0394
1.0000
#60
0.0400
1
The last number is the metric equivalent of the drill bit size. So a #65 drill bit is about the same size as a 89 main jet.
I tried this
And installed the drilled out jet and rode the bike again. I got temps of 375- 380 and a max of 397.
Better but still too hot if I want the engine to last. So I tried again and drilled the main jet out with a #64 drill bit. That is approximately equal to a 91 main jet.
Took a ride again, and each time I rode a couple of miles at wide open throttle and climbed a long steep hill.
This time I got temps of 340-350 with a max temp 376. I'm calling that GOOD. It was about 70 degrees outside but I think I'm in the safe zone enough to be good for Summer.
If you don't want to spend $10 for each jet and then wait for it to come in you might want to try my method.
It did work !
