I've mentioned it already in a bunch of other threads but in case you didnt read them, I'm trying to put an AF18E (Dio SR) motor into my Nifty Fifty (similar to a Spree)...
I was checking it out this afternoon and it seems as though the shock mounting point on the AF18E is further back than it was on the AF05E stock motor. Is this the case with Spree conversions as well?
For all those that have done this conversion in the past, did you have to modifiy the Spree frame shock mounting point or did you use the same point as stock?
Dio-Spree conversion Shock position?
