99 elite SR Stock cylinder and gears (49.7mph gps verified)
LMH
Post by LMH »
And a video of the final ratio to show its a 12:1 and not 9:1. Ill do a much better top speed run some other day.
Click on the video to go to the photobucket movie thing.
99 Honda Elite SA50P SR 725 miles
Stock cylinder and head never been opened
Malossi CF reeds
Stock intake
Stock carb 89.5 main jet Clip in middle
Polini air filter inside stock intake with modified air tabs
KOSO coil and NOLOGY wire
NGK BR9HSA
Malossi CDI I believe part number 55-8132
PG short exhaust
Malossi Multi Var with 48Gs of polini racing roller power
Stock OEM honda belt
Stock SR rear pulley with Malossi Delta clutch and winged bell with the yellow center spring
OEM tire
200 LBS rider who doesnt tuck or roll.
paulpauly7
Re: 99 elite SR Stock cylinder and gears (48mph gps verified
Post by paulpauly7 »
nice work ive just finished a af27 dio the motor/cylinder/exhaust/carb/gears are all stock .All i have done is some cvt tuning daytona vari and ramp and a malossi yellow rear spring and it tops at 46 mph and cruises at 40mph nicely
Yes on a stock geared scooter - wow. What's your RPM??
LMH
Post by LMH »
I forgot to look at the RPM after I shut her down but it wasnt a high revving ride that time, Id say around 9100. Thats why I know itll do more still, just have to get a warmer day.
I think the malossi yellow is key for stock cylinders, Im going to order the chameleon and the daytona ramps next time I order from webike.
deuce217
Post by deuce217 »
sweet saddle bags!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
ped
Post by ped »
that's very good speed LMH.
I can only go 43mph on my stock gears.
p.s. nice bags.
LMH
Post by LMH »
49.7mph out of a 49.7cc!
LMH
Re: 99 elite SR Stock cylinder and gears (49.7mph gps verifi
Post by LMH »
Im debating on putting the 9:1 in it, I really like the take off it has with stock gears tho. I only have a handful of hours to mess with it right now. Im in town for 2 days and during the ride yesterday it started raining. When pulling into the drive she started to bog out so hopefully its from the rain, if not hopefully it was the cylinder ha.
Congrats on reaching the Scooter Holy Grail of 1 MPH per cc. Next project: Honda CBX 1050cc.
LMH
Post by LMH »
It really felt like 49.8, but Im certain theres nothing more left in the gears. That was where it always maxes out to on the cluster, it barely feels safe on the engine at that speed and rpm. I think it will drastically deteriorate at these speeds.
I don't feel there's all that much difference in midrange acceleration, regardless of the gearing. When I swapped from 7.58 to 8.44s - that's a pretty big 11% jump - the acceleration from zero to 5 improved considerably. However once the clutch is fully engaged, acceleration seems no better than it was. The variator just works on different diameters, but it still - umm... Variates, according to the load and spring.
One big improvement I'm having a hard time explaining was the addition of my new Malossi-for-ZX belt from Eftie. It grabs and goes better I guess, but why?
LMH
Post by LMH »
Less flex thanks to Kevlar reinforcement, the bandos wont wear away the drive faces and variators like the kevlars will tho. Something has to give you know.
Im going to do the 9s swap either tonight or tomorrow before Im back to the mother land to see the mother.
veedubh20
Post by veedubh20 »
my stock jog goes fast 56 mph.
LMH
Post by LMH »
Get some pics posted brother, stock jog power and gears@ 11,600 rpms is 52mph, the zuma is the same. I have already been down hill for .9 miles on my NextOne and my bug eye and never ever ever hit over 52. I run a lot of mods on my stock bug eye to even reach 52, Id love to see what you did to yours to make it 6mph faster than mine with the $1200 in bolt ons. Stock cylinder and gearing correct? No confusion as to what you consider stock.
I know all the parts have to be in synch with the minas unlike the hondas and maybe I dont have mine set up to the full potential. Show me the way.
spreeinkc
Post by spreeinkc »
My stock Jog was faster than any of my stock Hondas but I never came close to even 50mph. All I did was remove the washer between the variator and it would peg the speedo. I think 47mph is fastest it went and that was down a steep hill.
