Fuel tank plastic screen/tube
Posted: Thu May 08, 2014 7:39 pm
by Jimmy Appel
There is a very very fine mesh plastic pick up tube inside the Honda Spree 50cc fuel tank between tank and petcock. Is it safe to soak this plastic in carburetor dip/cleaner?
Re: Fuel tank plastic screen/tube
Posted: Thu May 08, 2014 8:09 pm
by Johnniespeed
No, even though the carb dip of today is much weaker than it used to be, the risk of plastic damage is high.
I would give it a quick blast of aerosol carb spray, followed by a quick blast of compressed air. I have done that many times, was able to get the screen squeaky clean without any damage.
Posted: Sat May 10, 2014 2:11 pm
by patthesoundguy
Even spray carb cleaner can melt some plastics if left too long. So being quick is a good idea but I think you'll be fine if you dont leave it too long. Johnniespeed has the way right to do it :-) compressed air after the spray :-) compressed air is your friend. ;-)
