92 yz125 lc engine running temps ?
- paulpauly7
Well ive got it running and im gonna fit my trailtech vapour .What is a good running temp on these LC machines ? also a danger point temp ?. Any help would be great
Re: 92 yz125 lc engine running temps ?
You need the water temp send unit. Running temp shouldn't ever reach over 200 coming out of the block, if it is figure out why it's running hot. I shot for 180-185 out the block.
- paulpauly7
thanks lmh can i not use the spark plug kit like what i got from graphite?
That's for air cooled engines and your reading won't be as accurate. It will work but it won't be like the ac engines. I don't know how inaccurate it will be but if you don't see the head temps you expect know that's why.
- paulpauly7
Thank you dude
