Fixed top speed by cracking open airbox. Is that BAD?
I finally figured out that my spree will go from 25mph flat to 31-32mph on flat ground just by cracking open the lid on my airbox. Just wanted to check if that will damage my engine at all. All i did was just pop open the latches, the lid is still screwed down tight. I saw that some people wrote to drill four holes in the airbox for faster speed. Can't see how this is different but thought I should check. Thanks. Man these sprees are finincky!
- burnt_toast
