SB50 intake mod for Spree
Read up at the link, and comment here. Details on SB50 intake and reeds for the Spree motor.
http://www.hondaspree.net/phpBB/viewtop ... 7090#27090
MySpree
Post by MySpree »
you relize that you will have to mix gas then, becuast on the sb50 the oil is injected into the carb and not the intake. i alredy went down this route. i had one on my 45mph spree, but it also had a sa50 carb.
Post by Kenny_McCormic »
or you could keep the oil injection and install a manual petcock or even better install a sb50 carb while your in there
the sb50 is an aero right?
se50
Post by se50 »
SE50 engine is very similar to an Aero, if not identical.
1985 Kawasaki Bayou 185 ATV
1984 Yamaha IT200 enduro
MySpree
Post by MySpree »
no might well call it a spree on a low dose of steroirs.
windycity85
Post by windycity85 »
sorry to bring back an older thread but has anyone had any success with this sb50 intake? what do you have to do to get it running right? always flowing petcock AND premix?
thanks in advance
1986 Spree - Sold!!!!
2005 BKM Jazz
MySpree
Post by MySpree »
ok, whoever said something about a constant flowing petcock is crazy, you don't need one, you can use a stock one. the sb50 intake sb intake is from an elite E not from a honda aero, to use a sb50 intake you must use a sb50 carb or run premix. with the 85 aero you can use the intake and you spree carb but it can only be from a 85
yeah but if you had a constant flowing petcock you could inject oil through the vacume port you just freed up instead of running premix
windycity85
ok so just get the sb50 carb and intake and I should be ok?
2005 BKM Jazz
windycity85
anyone? i think that is right but i want to make sure.
2005 BKM Jazz
windycity85
forgive me but I do not know too much about elites, but would an 87 elite have the carb and intake I need or would it need to be a newer one? I found one for a decent price so i hope that is the year, but I get a feeling it isnt.
2005 BKM Jazz
MySpree
Post by MySpree »
no the 87 will not fit is is a 4 bolt.
windycity85
thank you!!! what year range am I looking for then?
2005 BKM Jazz
Maybe I'm just a simple old hot rod guy, but why not just drill and tap a hole and install a second nipple in the intake if you are going to use the Spree carb?
burnt_toast
Post by burnt_toast »
sure that would work too.
old thread revival woot woot! haha
projects galore :nerd:
