UNI-Filter security
UNI-Filter security
I have UNI filter on my Aero 125.
the first RED OUTER SLEEVE disappeared without reason.
I wondered if it was "lifted" by an unscrupulous passer-by,
or did it just get flung into the universe by the massive air pressure created by Ruby's blazing speed.
Either way, and now, a SECOND sleeve has managed to wriggle it's way free.
ANY suggestions to secure this sleeve to the filter body and end this exodus of expensive foam cylinders ??
Re: UNI-Filter security
Post by swimmingfree »
i have lost UNI filter the hole think a time or two ..... so i put a string throw the UNI filter and too the cable so if the damm thing come off its still on the scooter...
Yeah, the red bit tends to blow off randomly. I once tried a few spots of contact cement to wed the twain but the oil in the sponge prevents stickage, even on a new unit. If I still had one I would consider a small zip-tie through both layers.
patthesoundguy
Post by patthesoundguy »
I just tossed my red sleeve for my uni on the shelf ;-)
patthesoundguy wrote:I just tossed my red sleeve for my uni on the shelf ;-)
yeah,...the effect is likely more aesthetic than function anyway...right...no worries... :urban:
Red Eft Performance
Post by Red Eft Performance »
Ya Really the Red cover is for off road vehicles. Just a dust cover. Easier to clean between rides and between full air filter cleaning.
But its pretty easy to get creative about making sure it doesnt come off.
I may have used a couple paper clips before.
Keith
Red Eft Performance
View products click => Here
Wiscompton
Post by Wiscompton »
I have found that hot glue works well to hold filter foam together.
87spree70superbee
Post by 87spree70superbee »
Try 2 zip ties? If you can make em tight it'd be hard to come off.
Black 85 Spree-SOLD
Red 87 Spree... Ended up buying the same one mentioned below.
I started riding my uncle's 87 Spree at the drag strip when I was 8...
It's easier to stop caring three years ago than it is to fix it in present time.
LMH
Post by LMH »
I usually loose the whole filter, I started tieing a string to mine. The paper clip worked good to hold them together for me.
sew it on with thread :wink:
