125cc stroker?
dio boy
125cc stroker?
Post by dio boy »
Having a water-cooled 125cc stroker built and sent to me. i am just looking for tips on tuning and maintenance or anything helpful. Previously all my builds have been 72cc that i have built new to the stroker game. Just want it to last. thanks!
Downsouthdio
Re: 125cc stroker?
Post by Downsouthdio »
Get ready for some stuff to break lol..i broke a c├┤uple fans..but just run good oil everytime and make sure you have a temp guage..good luck..i sent my block to hawaii actually to get cut and have the bore and block ported..good luck!! :thumbwink:
Honda super dio
Corsa
26mm
Sparrow
LMH
Re: 125cc stroker?
Post by LMH »
Where did you find the 55mm jug? I could only find a 54 Lc cylinder for my 120cc Lc stroker build. I haven't started the build yet and if I can get a 55 I'd rather do that.
deuce217
Re: 125cc stroker?
Post by deuce217 »
LoveMyHonda wrote:Where did you find the 55mm jug? I could only find a 54 Lc cylinder for my 120cc Lc stroker build. I haven't started the build yet and if I can get a 55 I'd rather do that.
Did you use the autotech355 kit? Do you have a build thread on that motor?
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
LMH
Re: 125cc stroker?
Post by LMH »
Jiangwayne is who I used for the 54, it's the china copy of John wayne. I'm still waiting to build it when I get time with everything else.
deuce217
Re: 125cc stroker?
Post by deuce217 »
LoveMyHonda wrote:Jiangwayne is who I used for the 54, it's the china copy of John wayne. I'm still waiting to build it when I get time with everything else.
Maybe I can bore your case for you when you get around to it. I am dying to take some cuts on the new bridgeport. I should have it wired up this month. It takes 3 phase power so I need to wire the rotary phase converter still. Last weekend I finally got it put in its place in the shop.
50mm BBK (tai)
V-8 pipe
Downsouthdio
Re: 125cc stroker?
Thats what i have..mh bore from jiangwayne
Honda super dio
Corsa
26mm
Sparrow
veedubh20
Re: 125cc stroker?
Post by veedubh20 »
You should have spent on minarelli jog wink! Here is the Taiwan 125cc crank blow up on Fb taiwan.. :coolcruise:
birdman
Re: 125cc stroker?
Post by birdman »
I crave the 125cc power. And I would love to embarass all the noisy Hollies from light to light when Im downtown.... But if I punch a whole in my AF16 block I will cry cry cry!!!
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
