Bigger gas tank for spree mod, work in progress
ped
Post by ped »
Hi forum.
I will be installing a bigger gas tank on a spree fame. modifications required.
I'm going from 2.5 L to 3.7 L. I can make this gas tank work.
I'm not using the oil tank and I'm not using the side covers so its easy for me.
if you want to try it you will need to premix. I think the gears stem pull off the spree pump?
also you have to shape and mold the tank to fit.
you will need 85-87 aero 50 1 gallon gas tank. and metal shaping hammer. a ball peen hammer may work. then go to town on the tank shaping it to fit. drill new holes add new bolts. add your seat. Good luck :smile:
ped
Re: Bigger gas tank for spree mod
Post by ped »
:smile:don't forget you have to remove your oil tank & premix
ped
Post by ped »
:smile:make sure you remove your fuel sender before you start banging on the tank.
you will need about half inch of space, on the back side of the tank for the battery clarence.
order a new on and off petcock from eBay. In line type. add a nipple to tank. that will give you clearance by the shock.
gperspective
Re: Bigger gas tank for spree mod (no post yet)
Post by gperspective »
looking forward to this :geekdance:
Pocket Change . Scooter Club
Honda Spree . AF16E
Polini Corsa - Naraku Intake - Dellorto 21mm PHBG - Malossi E8 AirFilter - Malossi Variator 7g - ZX Trans - 9:1 - PG Short
ped
Post by ped »
spree tank 2.5L, aero tank 3.7L or 1 gal.
The 83-84 aero gas tank is different and it's 3.2L tank. Only .7L bigger. a little over 1/2 a quart.
I did not check if 83-84 tank fits? but too small for me.
Add a premix bottle. A baby bottle works for me because the ounces marked on the side. :smile:
ped
Post by ped »
yes I will be adding this gas tank to my spree. as a winter project. :thumbwink: Good luck.
Make all the mods to the aero gas tank. that way you can put back your spree tank to keep it stock. save your old parts.
patthesoundguy
Re: Bigger gas tank for spree mod, work in progress
Post by patthesoundguy »
Stand alone petcock to get the clearance you need by the shock :-)
http://www.ebay.com/itm/271117102085?_t ... EBIDX%3AIT
Rip_City_Spree
Post by Rip_City_Spree »
Anyone ever moved the tank on their elite?
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
