Looking to buy an 85 jet for an sb50. I tried to cross reference parts but I'm getting confused with updated part number changes.
New part number for the oem 68 jet
99101-GHB-0680
I googled searched the same number but 0850 instead, and found the early xr80 and xr100's came with them.
I then went to my parts site and searched but found these part numbers are different now. What I found was
99101-GCK-0850. -$19.xx!!!!:0
99102-GHB-0880. -$3.xx. Much better.
If anyone knows for sure the part number I need I would greatly appreciate it.
Sb50 85 jet
Re: Sb50 85 jet
I'm not sure on jet part numbers but could try to find the Daytona jet kit I'm not sure how available they are but I had one back when I was stock carb tuning 80-105 mains was like $30. I ran the 90 in my stock set up with a slightly ported block and the wild lion and it was sweet.
Re: Sb50 85 jet
I'm pretty sure the PA Carb part number 99101-187-0850 should get a Hit on Honda-san's computer. Call the dealer and read it to them to see.
Re: Sb50 85 jet
Kevinstonge: "99102-GHB-0880. -$3.xx. Much better"
Price looks good, but beware, I have found no PA carbs in the list of "used on" models for that jet.
Used on 1987 Elite SE50P PA carb, will fit PA carb on SB50.
JET, MAIN (#85) 99101-187-0850 $5.94
+1Wheelman-111 wrote:I'm pretty sure the PA Carb part number 99101-187-0850 should get a Hit on Honda-san's computer. Call the dealer and read it to them to see.
Kevinstonge
Re: Sb50 85 jet
Thanks guys! That's the one for sure!mousewheels wrote:+1Wheelman-111 wrote:I'm pretty sure the PA Carb part number 99101-187-0850 should get a Hit on Honda-san's computer. Call the dealer and read it to them to see.
Thanks but no, that's not what I want. This E has a bore kit, stock carb and exhaust.Pete M wrote:This is what you want
22 99101-187-0680
JET, MAIN (#68)
