Anybody know of the 50mm (pop) kit liquid
- Dustyn2007
- BMX
Hello wanting to get info on the pop kit it's not made any more my buddy just bought it and was wanting to see what cranks work best plan was to use stroker crank ( I thought you could make any cylinder a stroker motor I assume I'm wrong any info is appreciated
Re: Anybody know of the 50mm (pop) kit liquid
As long as you have the correct port timings any crank can be used. Now there's more to it than just that but do some research on how to stroke a 2 stroke. Base plates, machine work, port work, correct exhaust, etc.
- Red Eft Performance
There is a good chance that 50mm POP kit is for a mini stroke crank. If it is a large stroke crank probably isnt going to work.
Keith
Keith
Red Eft Performance
View products click => Here
Ya I doubt the 50mm bore is set up for the 52.6.
- Downsouthdio
I was gunna say earlier ..ive seen many setups with that bore using a ministroke crank..at least alot of hawaiian guys setups ive seen
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Correct me if I'm wrong...the 50mm POP is a non stroker bore. It can be used on a mini stroke or stock crank but not on any stroker crank which i been told in the past.
