Oko carb tuning help
Posted: Thu Jul 24, 2014 11:08 pm
by Dustyn2007
Just installed 21mm oko and black intake and it has 103 main 42 pilot to get it to run air fuel has to be screwed all the way in and idle all the way in / up max temp 260 I put 107 jet in ran like sh"t should I keep going down? I have molassi bbk cast
Re: Oko carb tuning help
Posted: Fri Jul 25, 2014 2:26 am
by patthesoundguy
Up the pilot jet to get it to idle. Basically you want you get the size of pilot jet that you can get the idle air screw about 1.5 to two turns out that way you have some tunability with it. If the pilot jet isn't right the transition from bottom to mid range throttle will suffer.
Posted: Fri Jul 25, 2014 9:44 am
by Dustyn2007
Would moving clip on needle do anything?
Posted: Fri Jul 25, 2014 9:48 am
by swimmingfree
what size bbk do you have ????
moving the clip i thing will help the mid range...
this may help
Posted: Fri Jul 25, 2014 10:01 am
by Dustyn2007
72 malossi cast so moving the clip down will riching? My other bike has same set up but has 24 mm carb with same size pilot and no probs
Posted: Fri Jul 25, 2014 10:08 am
by Dustyn2007
Some people say I may have air leak but if I did would it be hard to start and idle erratic. What's best way to check ? Starts right up and runs good I new to the carb tuning
Posted: Fri Jul 25, 2014 10:10 am
by swimmingfree
me two... lol i wood start with the pilot jet and down size it ... get the low end to be wright first... then work on the middle then the top ....
Posted: Fri Jul 25, 2014 12:48 pm
by Dustyn2007
So is screwing in riching or out few people say diff just trying to be sure
Posted: Sat Jul 26, 2014 10:32 am
PTSG gave you the correct remedy in the second post. ANY fiddling with screw a clips and mains is pointless if the Pilot is wrong for this setup. You can't latch on to another engine as Truth for what's Right for the Iron. Different carb, manifold, but also port timing and exhaust will and does result in some weird jetting needs. In this case it appears your 21 OK needs a bigger Pilot than your 24. Put it in and see.
