85 spree bogs down at 15mph
don-tardo
Post by don-tardo »
From searching the forum this looks fairly common but there's no one reason that this happens so I'm stuck. I have an 85 spree that starts and idles like a champ. It has great acceleration but I get it up to 15 or 20mph and it backfires and dies. I pulled the plug-it was black. I changed it and took off the air box to see if that would correct it but it didn't help-still fouling the plug and bogging down. I cleaned the carb-no change. I cleaned another carb I had and tried that one-noticably better acceleration but the same thing around 15 or 20mph. I have a feeling the bystarter may be choking it out but I'm nor sure how to check it. If anybody has any suggestions I'm game. I have tomorrow off and I want to get this thing running right so I can have some fun. Thanks for the help.
1 screaming 85 Spree
1 sacrificial 85 Spree
reckless504
Post by reckless504 »
you have proper gap on spark plug? also it could be the voltage regulator thats the acouprit or however you spell it came out to be when i tried everything on my '84 spree to get out the bogging at like 10-15mph. also check to see if the hose on the airbox is in correctly and clamped on the carb so no air leaks. also take a look at the air filter to see if it is dirty or something. thats about the only thing i can really think of soo hope that helps (: - matt
1986 Honda Spree w/ pulley mod clocked in at 37mph hauling 175 lbs. Don't believe me? lets race!
Farfignugin
Post by Farfignugin »
black as in wet-black or dry black?? Because backfiring is usually a sure sign of running lean. Might wanna clean ur carb and check the jets (main jet) to see if they are plugged.
ejames81
Post by ejames81 »
you may have oil in the block. this happens with suzuki mopeds. if you want to check it, remove the intake manifold from the block and look inside.
don-tardo
thanks
Post by don-tardo »
Thanks for the help. At first it seemed to be running rich so I opened up the airbox, this caused it to run too lean. I put in a new, clean and oiled air filter and that did the trick...man are these things sensitive. It's latest trick is the battery dying. I put a new battery in, charged it and ran it about 12 miles. When I went to re-start it 10 minutes later it was dead. The lights were on (dim but on) but it didn't have enough * to turn the starter. I jump started it-ran home and the same thing happened. Any idea what's killing my brand new battery?
MySpree
Post by MySpree »
the alternator might be sucking power instead of makeing it.
