Hi there everybody, so I got myself a 2005 Yamaha Vino 125 from a kid who said it didn't run after installing a new V-belt on it. After tinkering with it for less than an hour, I got it started. It runs beautifully other than this gross grinding noise coming off the variator side. Now I can't tell if its an improper kickstart gear install, or if he put the variator on wrong when he put it back together, but I took a video of it momentarily just to show what I'm hearing. If anybody has any thoughts on it please feel free to throw some advice my direction. Thanks a bunch! Here's the link to said video:
https://www.youtube.com/watch?v=WVhAT5pnoGg
Yamaha Vino Variator Grinding Noise
HarrisonFallow
"Anyone who calls you "uncool" for riding a scooter is just a soul trifled with envy."
- 05' Yamaha Vino
- 86' Spreedio
- 86' Spree
- 85' Aero
- 78' Urban Express
- 05' Yamaha Vino
- 86' Spreedio
- 86' Spree
- 85' Aero
- 78' Urban Express
- cruzingratiot
Re: Yamaha Vino Variator Grinding Noise
take off the side cover take off the belt remove spark plug
put the variator and outer plate and nut on
turn over with a wrench see if it is stull there
if it is gone could be kickstarter
Donate Life
http://www.donatelife.net/
Thank You
Thank You
HarrisonFallow
Thank you very much cruzingratiot, I'll get right on it and let you know how it goes. I suppose even with everything as is if I hand crank it over and there's no grind that probably wouldn't be enough to bank on it being the starter gear? Thanks again!
- 05' Yamaha Vino
- 86' Spreedio
- 86' Spree
- 85' Aero
- 78' Urban Express
- 05' Yamaha Vino
- 86' Spreedio
- 86' Spree
- 85' Aero
- 78' Urban Express
check your variator makes sure, everythings there and its not got any thing going wrong with it. taht the two parts arent banging into each other.
